305/60-18 on D2
Old Nov 18, 2012 | 07:51 PM
fuelie68's Avatar
3rd Gear
Default 305/60-18 on D2
Hello, names Lew new to forum have searched but have not seen anyone that has put 305/60-18 on 03 D2. with 2" lift stock bumpers limited off road. DD
will they fit, rub themselves into 255's or what????
Answers appreciated stupid answers ignored.
P.S. I have enjoyed this forum so far,
Old Nov 18, 2012 | 08:09 PM
BrandonS's Avatar
305's for a Rovers weight are pretty wide. What kind of terrain do you plan on running? Thats what will determine your tire size. Check out this article...
http://www.expeditionswest.com/resea...tion_rev1.html
Old Nov 18, 2012 | 10:09 PM
fuelie68's Avatar
3rd Gear
Thank for your input brandon, to tell the truth i'll be dealing with winter and massive potholes in the Detroit Mi. area for now
Old Nov 18, 2012 | 10:24 PM
BrandonS's Avatar
In my personal opinion, 305's are way too wide for best performance. With that said, you didn't ask for my opinion on that; but I wanted to voice it
In any case, I have 265/65/18's on mine with a Terrafirma lift. I the 2" lift, but have HD springs up front and a 1" spacer on the rear. The lift came to 3". Your tires are going to be almost an inch larger in diameter than mine. I think you will most likely end up trimming your front bumper as mine are already really close. Additionally, if you are running stock rims, I'm not sure if you will rub on full compression or not. However, f you are street driving, this should not be an issue with a lift.
I think remember reading 33" is also around the point upgrading the differential and axles may start becoming a factor.
Old Nov 18, 2012 | 10:34 PM
fuelie68's Avatar
3rd Gear
Nice truck went to the site you recommended and found the exact information
I needed, plus after seeing your truck and how the 265/65's fit would have to say you are definitely rite 305's were a little bit ludicrous thanxx again
Old Nov 18, 2012 | 10:49 PM
BrandonS's Avatar
If you do like wide for looks, go with 285's. People have gotten away with those.
swiftrabbit
Jun 5, 2012 06:43 AM
NCguy
Feb 27, 2012 11:39 AM
frat daddy
Jul 11, 2011 04:23 PM
mx468
Nov 22, 2009 01:41 PM
nick1996rover
Mar 8, 2005 10:25 PM
