Can I fit 305/70/16 size tires on my 16" disco 2 rims?
Old Nov 17, 2009 | 10:26 AM
mx468's Avatar
Default Can I fit 305/70/16 size tires on my 16" disco 2 rims?
I was wondering whats the largest size tires I could fit on my discovery2 rims, 16". I currently run p255, 65, r16 on them. Would 305/70/16 fit on my rims without any alterations to my discos body? Whats the benefits and nonbenefits of larger tires. Thanks.
Old Nov 17, 2009 | 10:33 AM
It will be close, may need to go to wheel spacer to move that tire out and away from the inner wheel well siding.
What have you done to strengthen the dif for that much tire, your current spider gears won't take too much abuse from those big tires.
Old Nov 17, 2009 | 10:58 AM
NiteTrain's Avatar
the benefit is more ground clearance.
mike, is it the spider gears or cross pin that is the weak point?
Old Nov 17, 2009 | 11:02 AM
I have always felt the spider gear teeth are too thin/weak, also the use of only 2 spider gears instead of 4 is a big factor.
Old Nov 17, 2009 | 11:13 AM
NiteTrain's Avatar
mike, did you break your spider gears or did you put in lockers before they broke? what size tires are you running?
Old Nov 17, 2009 | 02:08 PM
With in a few months after buying my truck, joining the SCLR and weekend trails, I saw too many break and installed lockers, for that as well as the traction.
Old Nov 17, 2009 | 03:28 PM
mwindth's Avatar
Mike...if I run completely stock, but add 245/75/16 tires, will I have problems with my spider gears? I'm know the 245/75/16's will not rub with my stock height, but I never thought about the spider gears before this thread.
Thanks for all of your input.
Old Nov 17, 2009 | 04:40 PM
No, you'll be in great shape.
Old Nov 17, 2009 | 09:19 PM
AK Rover's Avatar
You're asking 2 very different questions at once. Yes, a 305/70R16 will fit on your factory 16x8 rims. I've run 305/70s on factory rims Dodge rims.
You're going to need a lift, probably 3", and more than likely a little trimming of the wheel well to make them fit. And you'll have to adjust your steering stops so much you'll be pretty much limited to driving in straight lines.
Old Nov 22, 2009 | 01:41 PM
NiteTrain's Avatar
mike were most of those breakages the rear diff? Have you ever seen a front break from running 33" tires?
jycsalas
May 23, 2019 03:02 PM
NCguy
Feb 27, 2012 11:39 AM
yukonridin23
Sep 22, 2009 01:18 AM
RoverDude71
Mar 2, 2009 11:03 AM
nick1996rover
Mar 8, 2005 10:25 PM
