32x11.50x16's and 2" lift
So I'm about to buy new tires and a lift. My question is will 32-11.5-16s fit with a 2" lift with out having to do anything else to the truck? Panhard bar, spacers, etc. $$ is very tight for me so I'm not going to do the lift and tires unless I can do it with just those two things. $160 is the cheapest per tire I've been able to find for the kind of rock/mud tread I'm looking for. They are pitbulls. Any one know of something better for the money? I need tires regardless so I guess my next question is what is the biggest tire I can comfortabley run at stock height? If I have to I'll run the bump stops out some. I currently have 255/70r16's on the truck now. Any one know what that's close to in inches?
What year do you have? Here is a tire size calculator. http://www.miata.net/garage/tirecalc.html
Willie
Willie
Your tire size currently is about a 30x10...... if your only going with a 2" lift you should be fine with your stock steering components. I can tell you i just put 33x12.50 Mickey Thompson Baja Claws, its a D1 with 5" lift and I had to do some fender trimming to make it fit if that tells you anything
