33s on a disco 2
Old Dec 11, 2011 | 11:47 PM
parksy's Avatar
Default 33s on a disco 2
does anyone have 33s or equivalant size on d2 . and if you have what did you do to get them on . i want to go bigger than current , 33s or 265 85
Old Dec 12, 2011 | 03:30 AM
cipher982's Avatar
I am running 275/70/18 ATs, comes out to 33.2" according to my calculations. I actually ran them with stock suspension for a small time frame. Though I had to dremel the plastic sorroundings a bit and adjust the angle of the front bumper so the bottom of it did not rub the tires. Running a 2" lift now and it's great, though still rubs at times when full-steering-lock parking.
Old Dec 12, 2011 | 09:49 AM
I would suggest a HD OME lift, giving you at least 2.5"s and you won't have any clearance issues.
Old Dec 12, 2011 | 07:54 PM
parksy's Avatar
hey thanx . when you talk about dremel < ive seen it written on a no. of things > do you mean grind , as in grind part of the guards cos I have no idea what dremil is
Old Dec 13, 2011 | 12:47 AM
cipher982's Avatar
Dremel - Wikipedia, the free encyclopedia
It's just like a smaller version of a drill. With attachments more focused on cutting and grinding. There's a plastic cutting bit I picked up at Lowes for ~$10 that slices through plastic like it's silk. Some of the plastic pieces sorrounding the tires rubbed up against the bigger tires. So I used this tool to trim off the parts that rubbed.
