33x9.50/15 tires - How much lift?
Old Jan 23, 2015 | 01:10 PM
98xc800's Avatar
Default 33x9.50/15 tires - How much lift?
I want to run 33x9.50/15 tires on my 99 DII, I have 31x10.50/15's now. Will 2" lift be enough with a bit of trimming? I am building a steel front bumper with winch and wheel with about 250lbs of gear and 3 passengers often. Should I get the medium or heavy springs? I am converted to rear springs already.
Old Jan 23, 2015 | 01:13 PM
slammin_LWB's Avatar
I have no real answer to your question, but one of my own.
Pics with BMW wheels? What style?
Old Jan 23, 2015 | 02:12 PM
dusty1's Avatar
2" if you plan on trimming and some extended stops....should work
3"....... you could get by with out the possible trimming
Old Jan 23, 2015 | 02:36 PM
3"....... you could by with out the possible trimming
x2 on what Dusty said and wanting pics
Old Jan 23, 2015 | 03:33 PM
jafir's Avatar
That's pretty much the size I had on mine, and I didn't have to trim anything with a 2 to 3 inch lift and and ARB front bumper. I had 255/85R16. I'm not sure what offset is on the 15" rims you plan on using, but assuming it's pretty close to stock you'll probably be ok.
Old Jan 23, 2015 | 07:32 PM
98xc800's Avatar
The rims are 90's bmw 5 series steelies. The bmw studs are 12mm vs 14mm on the Disco, so I drilled them and re-cut the lug tapers. I have been running them for 7 years now.
Attached Thumbnails 33x9.50/15 tires - How much lift?-image.jpg
Old Jan 23, 2015 | 07:45 PM
jafir's Avatar
You've got the fancy extended roof rails.
Old Jan 23, 2015 | 08:04 PM
98xc800's Avatar
Square tubing with ball bearings weld d in the ends, mounted with hose clamps! Goes great with the ratchet strap jack-all mount. Bush engineering!
Aj6543
Nov 10, 2010 10:41 PM
began
Nov 23, 2008 08:59 AM
LRDISCO
Feb 1, 2008 12:04 PM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
