3D Printable Parts Collection
Old Mar 10, 2022 | 03:56 PM
  #91
andino's Avatar
Anyone come up with something to help reinforce the bottom part of the cluster surround where the two screws go in?
Old Mar 10, 2022 | 04:52 PM
  #92
JUKE179r's Avatar
I had to use longer screws with washers.
Old Mar 10, 2022 | 05:05 PM
  #93
andino's Avatar
Hmm not a bad idea. I'm going to pull mine this weekend to fix the cracked bottom. Maybe I'll see if I can design something but washers are a simple and effective fix.
Old Mar 10, 2022 | 09:44 PM
  #94
robertf's Avatar
Old Mar 10, 2022 | 11:04 PM
  #95
andino's Avatar
Would you be able to share the STL for the spacer? @robertf
Old Mar 11, 2022 | 10:14 AM
  #96
robertf's Avatar
stl file attached
File Type: zip
Old Mar 11, 2022 | 06:38 PM
  #97
The_OGCJR's Avatar
I want a complete Binacle. At this point, I’m inclined to glass it
Old Mar 12, 2022 | 10:03 AM
  #98
gulfstream69xr7's Avatar
Has anyone printed the J trim piece that is above the exterior A pillar? I was unable to print it. I'd be interested in buying one if somebody has successfully printed it.
Old Mar 15, 2022 | 10:22 PM
  #99
Brandon318's Avatar
Anyone able to make a file or print the spark plug wire brackets that mount to the back of the heads? They're NLA :/ I can send someone this actual (albeit broken) one if it's helps. The brass insert isn't necessary. Washers can just be used instead.
Old Mar 16, 2022 | 12:41 PM
  #100
Richard Gallant's Avatar
I might have a spare set will check later today
