3D printer guys, need some help
Old Apr 25, 2024 | 08:22 AM
sqlbullet's Avatar
I am gonna go odd man out here and say maybe not 3D print. I am assuming you want to put this back on a vehicle/expose it to elements and UV. I would be more inclined towards a sand mold and cast in aluminum or brass, or have something CNC'd from aluminum. My son does some casting, I will ask him about feasibility and if he knows how to find someone near you that could do it.
Old Apr 1, 2026 | 06:27 AM
eldridgewil's Avatar
Originally Posted by greisinb
So this can be 3D printed but like Alex said, this is an idea candidate for restoration as it will probably be easier and way cooler. I assume its made of aluminum? You could take it to a powder coating place or a body shop and have them quote the job for you or if you are looking to do it yourself I would:
1) Strip off the old paint. This might be pretty time consuming so it might be worth asking a body shop or powder coating shop to sand blast it for you.
2) Spray it with a coat of British Racing Green.
3) Go over the raised portions with a sander to remove the green paint from the raised features
4) Using a sponge apply a white paint to the raised features
5) Seal it with a polyurethane (or similar)
Hey guys, if you’re tackling custom parts for your Discovery II and thinking about using a 3D printer, one thing that really helps is keeping all your measurements, reference photos, and part specs organized in a way that’s easy to share. I’ve started using https://comfax.com/ to store PDFs of templates and modification notes - it’s simple to upload, annotate, and even send out when someone else is helping with the design. If you ever need to send a physical copy of a spec sheet or build instruction to a mate who still uses a fax at work, that platform makes it pretty straightforward without having to dig out an old machine. Just make sure your CAD exports are in the right format and include clear dimensions so whoever’s printing the parts knows exactly what tolerances you’re aiming for..
thanks for the information!
Old Apr 1, 2026 | 12:59 PM
Sandman614's Avatar
Originally Posted by Dervish
Put in a normal scanner with a good ruler, and You have it as a picture with dimension reference.
This or a good straight on picture, then import it into Fusion360 or other 3d software, trace it out, done
sblvro
Jun 7, 2022 09:41 AM
Ted Kresge
Apr 14, 2020 03:10 AM
No Doubt
Jan 17, 2020 02:56 AM
Spike555
May 24, 2009 03:45 PM
