3rd gear problem
Old Feb 10, 2013 | 02:39 AM
Big nic's Avatar
5th Gear
Angry 3rd gear problem
Hi all I'm having trouble with my auto box it sometimes go's into 3rd gear and sticks there iv changed the oil and filter went a run all was fine when I got home put it in revers and then drive and it was in 3rd again turn it off and wait 10 seconds and away u go in first any help would be brilliant
Old Feb 10, 2013 | 09:31 AM
Bkreutz's Avatar
Sounds like the gearbox is going into "Safe Mode". When it does this, what does the gearbox display in the instrument cluster show? It will not read the same as when the gearbox is operating normally. First suspect would be the XYZ switch on the gearbox (wet or corroded).
Btw, are you in Canada or Scotland?
Old Feb 10, 2013 | 10:48 AM
When in Safe Mode, the tranny is locked into 3rd, which is not what he is describing.
Old Feb 10, 2013 | 04:57 PM
Bkreutz's Avatar
Sure sounds like he said it's locked into 3rd gear to me.
vvrrrmm
Dec 13, 2021 09:08 PM
big_boi
Freelander
Oct 15, 2010 06:12 AM
Lee1140
Dec 1, 2009 10:17 AM
99XJ
Mar 17, 2008 09:03 AM
