4.0/4.6 rebuild
Old May 27, 2021 | 09:35 PM
Tony Luna's Avatar
Default 4.0/4.6 rebuild
Just got the block from the machine shop. I’ll start to build with the parts in the sig after a thorough scrubbing.
More pics to come.
Old Jul 13, 2021 | 10:58 PM
Tony Luna's Avatar
Speeding this up as my original 4.6 has a misfire. Getting the right size rings for “B” pistons was a pain - got a sized set from Total Seal. Bought a cam and timing parts today. Installed the crank and plastigauged. End cap, cruciform seals, and dowdy washers next. Then pistons…
Old Jul 14, 2021 | 01:45 AM
The Deputy's Avatar
Every engine rebuilding class l've taken, suggest using the plastigauge off center of cap, about a half inch, to get better results.
Looks good, though.
Good luck with rest of rebuild.
Old Jul 14, 2021 | 05:50 AM
XRAD's Avatar
there are some 'upgraded' style cam bearings...which did you use?
Old Jul 14, 2021 | 10:09 AM
Tony Luna's Avatar
Looks good, though.
Thanks. Good to know. I’ll do the rod bearings that way.
Old Jul 14, 2021 | 10:15 AM
Tony Luna's Avatar
Standard. I thought about re-installing the upgraded ones - but decided to leave well enough alone.
Old Jul 14, 2021 | 12:36 PM
Extinct's Avatar
After you get it all together spray paint the exterior with clear paint to seal the block and help keep it cleaner when you have oil leaks. Clean engines are easier to find leaks and work on. Also, if you have not replaced the rear cam plug yet make sure you silicone it in, I have pulled more than two engines that were leaking from that cam plug.
Old Jul 14, 2021 | 11:23 PM
Tony Luna's Avatar
Oil leaks??? Ha!
Good idea. Matte 2K.
I do have a new cam plug. I was thinking about using the same Permatex Aviation sealant I used for the core plugs. The rear core plugs (either side of cam plug) did go in much easier than the plugs in the side of the block. Hoping the sealant will do it’s job there…
Old Jul 19, 2021 | 04:41 PM
Tony Luna's Avatar
Made some good progress this weekend. Ordered all the timing gear from Rimmer Bros on Tuesday, got it on Friday - 3 days!!!
Old Jul 21, 2021 | 12:08 PM
Tony Luna's Avatar
Almost crapped myself when I saw this yesterday. Turns out, nothing seems to attach to it - at least not on the existing engine in the truck.
Also, narrowly averted disaster. I almost threw away the box that the machined crank came in - I actually put it in the recycling bin. Then, I had a second thought and kept it to put the old crank in at some point. Two days later when I realized the woodruff key I received from Rimmer Bros was the wrong one, I looked in the box I almost got rid of and found the original key in a plastic bag - Whew!
