4.0/4.6 rebuild
Old Aug 3, 2021 | 11:12 PM
Tony Luna's Avatar
Just got these in the mail. Rocker Arms Unlimited in Redding, CA. Sent in a set of cores and got these back 2 weeks later. Re-bushed arms, re-chromed and ground shafts, checked and refurbished cups and tips - original LR parts. Prompt, friendly service, and a very fair price. I’m confident they’ll work well - but will double check against engine manual before installing.
Old Sep 13, 2021 | 09:47 PM
Tony Luna's Avatar
Out with the old…
Got some wiring to clean up and new sensors to buy before putting the new engine in.
Old Dec 21, 2021 | 12:44 PM
Tony Luna's Avatar
Progress!!!
Old Dec 21, 2021 | 08:16 PM
Extinct's Avatar
Purty
Old Dec 21, 2021 | 10:20 PM
Tony Luna's Avatar
Originally Posted by Extinct
Purty
Hope she runs as good as she looks…
Old Dec 22, 2021 | 01:39 PM
dswilly's Avatar
I think starting a brand new engine would be both terrifying and exhilarating at the same time.
Old Dec 22, 2021 | 05:57 PM
Extinct's Avatar
Paint it with clearcoat paint before you start it to seal the aluminum from oil stains
Old Dec 25, 2021 | 01:00 PM
Tony Luna's Avatar
SUCCESS!!!
Fired right up and ran smooth. 30 min at 2-3K RPM to break in the cam with break in oil and ZDDP. Changed oil (more ZDDP) and filter and have about 150 miles on it so far. No more leaks (yet)!
Truly surprised it ran after all the new parts and engine compartment re-wiring. New coil packs, refurbed injectors, new plugs and wires, crank and cam position sensors, replaced all injector connectors, CPS connectors, knock sensor connectors, and a hand full of more connectors due to cracked/brittle wires.
Hope the cam survives…
A few codes - mostly due to bad upstream O2 sensors. Waiting to run normal oil (Shell Rotella) after 500 miles before new O2 sensors.
Old Dec 25, 2021 | 04:06 PM
Extinct's Avatar
Good job!
Old Dec 25, 2021 | 11:23 PM
Tony Luna's Avatar
Good job!
Thanks - time will tell.
