4.0 block to 4.6
#22
and exactly when did you two become published author's on LR's ? there are a few already. Try reading Des Hammill or some of David Hardcastle publications, get yourselves published a few times then I might trust your obvious OPIONIONS.
Also just you would be quite surprise what a "district zone manager" does and does not know. They did not get in those positions because the don't know ****, they are in those positions because they have the knowledge to deal with customers and out side service personal that a dealer has no way to rectify the problems.
Just my opinion
Just my opinion
#23
#24
Ok, well, thanks for that. Actually, I have a good collection of Hammill and hardcastle books in my posession already. I also have Vizard, Carroll smith, Joe Pettit, smokey Yunick, and many others. I also have god knows how many books on machinery design, manufacturing, machining and general engineering principles books.
I obviously don't know what a district manager knows, but strangely enough I don't aspire to know what a district manager knows. He has his speciality; and clearly has the knowledge sufficient to get to that position of authority.
I however, have knowledge of materials, how **** is cast, machined and assembled in production environments. I don't need to research what "adhesive was used". I know already there was no adhesive used. Experience has told me this. First-hand experience.
As regards the subject of the material used in the casting:
Alloy used in the casting of the Rover V8 blocks and heads. - Land Rover Forums : Land Rover and Range Rover Forum
A simple google search would have bought that up.
Mine too.
#25
Why is everyone trying to throw out their resumes? Admittedly, I haven't read books XY&Z, nor do I have a PhD in machining stuff. My bookshelves contain all the self help books my wife wishes I would read but don't. So, being in the same predicament 6 months ago, I spoke extensively with J.E.Robinson and Mark at D&D Fab. They both said that if you want a 4.6L without all the faults, you gotta go with a 99-00 P38. Their experience is without question and since they have no incentive to mislead in this particular area, I tend to trust their judgment. I went with a 00 Range Rover Bosch 4.6 for my top hat liner conversion, although with only 5K mi on it, I wouldn't really expect to see any issues no matter which block I used.
So maybe those years are the best/maybe not..any reason not to source one vs a different year? They don't cost extra, so why not error on the side of caution?
#26
"I however, have knowledge of materials, how **** is cast, machined and assembled in."
Then you KNOW that there are good castings and bad castings, and if you ever worked in a foundry you would know that.
So you cant say just because everything was spec to be cast a certain way, doesn't mean it gets cast that way.
Might have been too hot, too cold may have been after a Manchester/United.
The 03 block Feisal is a prefect example of machining differences that can effect a casting.
So I will also stick with the real world experience, which is why I bought a 99 gems.
And smokey Yunick were did you dig that name up from he hasn't been relative since the sbc was new,
and I don't ever remember him running rovers.
Blakesrover
02-21-2013 01:43 AM
JBEGIN
06-27-2009 12:38 PM
