4.0 engine in an 03 disco
Old Sep 21, 2018 | 01:17 PM
Jacobp's Avatar
Default 4.0 engine in an 03 disco
Quick question for reassurance, will i run into any problems putting my 4.0 engine in the 03 discovery since it originally runs the 4.6?
Old Sep 21, 2018 | 01:24 PM
Charlie_V's Avatar
No, unless one is SAI and the other isn't.
Old Sep 21, 2018 | 01:46 PM
Jacobp's Avatar
Thanks, ill check to make sure!
Old Sep 21, 2018 | 02:47 PM
The Deputy's Avatar
Edit: wrong information.
Old Sep 21, 2018 | 03:07 PM
2Guinness's Avatar
Yes, they use a different crank sensors/flywheel configuration. Either you have to modify the 4.0's mounting area to accept a 4.3 crank sensor (which l believe takes a little aluminum welding to change mounting area) and use 4.3 flywheel...or you'd have to figure out the wiring harness issue for changing sensor to 4.0 style (which, l've never seen a write up on, but may be out there somewhere).
And yes, as Charlie mentioned...if one is SAI and ones not...some computer changes need to be made and reprogramming is in order. Edit, unless you don't mind looking at CEL.
Brian.
I think you mean the 4.6 crank sensor yes? Are they not the same on the 4.0 and 4.6? What if you use the 4.0 flywheel.. do you still have to change the sensor and weld the block?
Old Sep 21, 2018 | 03:20 PM
2Guinness's Avatar
I have a 4.0 motor being delivered next week for my 03 4.6 D2 I was assured by the seller that there would be no issues with the exchange. I hope he wasn't lying to me.
Old Sep 21, 2018 | 03:35 PM
The Deputy's Avatar
Edit: wrong information. Apologies for steering the conversation in the wrong direction.
Brian.
Old Sep 21, 2018 | 03:41 PM
The Deputy's Avatar
Edit: wrong information. It looks like it is a direct swap.
​​​​​​​ Brian.
Old Sep 21, 2018 | 04:09 PM
Jacobp's Avatar
Im putting my 4.0 and transmission into the new rover, uusing the same trans would mean no flywheel worries right? As far as the crank sensors i was told about the wiring harness change like you said. Going from basic to sai tho, would the lack of this system cause a check eng light?
Old Sep 21, 2018 | 04:51 PM
mollusc's Avatar
Since the '03 will be expecting to see SAI, it will throw errors if it doesn't find it. You could take care of it by using the SAI-equipped heads from the 4.6 engine.
