4.6 and 4.0 front timing cover interchangeability
Old Jun 2, 2025 | 01:12 PM
Bone9's Avatar
I know this is an old thread but how did you get on with the front covers?
Old Jun 2, 2025 | 01:55 PM
PickleRick's Avatar
I'm currently running the 4.0 cover on a 4.6. only have about a week run time on it. So far so good. 40 plus psi warm at idle with Rotella 20w50 in the south east. All new bearings and oil pump.
I don't recall wot PSI but I think it was over 65. Measured via oil filter pancake. I don't drive the rover often.
The 03 had a broken timing chain and oil pump. The chain cracked the cover. Dowel pins were removed from the block for experiment.
Old Jun 2, 2025 | 03:23 PM
Bone9's Avatar
Ah gotcha. Do both of the covers have the angled oil filter or does one aim straight down?
Old Jun 2, 2025 | 03:50 PM
PickleRick's Avatar
That I couldn't answer, it's been too long since I held both against one another. If memory serves me correctly the only difference besides the giant window the damaged timing chain put in the 4.6 cover when it snapped was the absence of threaded ports for the oil cooler.
The 4.0 is angled, I do recall that much
Old Jun 2, 2025 | 04:10 PM
Bone9's Avatar
Ah ok I see. My 4.0 is angled and have a eye on a 4.6 from a range rover that's straight down. Wanted to know if that front cover is compatible.
Old Jun 2, 2025 | 04:12 PM
PickleRick's Avatar
My 4.6 is from an 03 disco, likely being the difference.
Old Jun 2, 2025 | 04:13 PM
Bone9's Avatar
Ah I see, I'm in the uk so only have 4.0 discos here.
Old Jun 2, 2025 | 04:24 PM
PickleRick's Avatar
Will happily find NA spec 4.6 disco motors for you and trade for UK spec diesel with matching slush box!
Old Jun 2, 2025 | 04:31 PM
Bone9's Avatar
Bit of a job doing an exchange!!
Old Jun 3, 2025 | 08:39 AM
PickleRick's Avatar
Been many years since I was on a plane, so you're saying a 300tdi or td5 isn't carry on?
