Which of 4 ABS Codes to start with?
First time using abs amigos module and here is what I got.
1.--Current Faults---->
Active Faults:
None
Logged Faults:
021:Engine PWM signal bad
040:Pump relay open circuit
065:Rear Left sensor electric fail
Rear Left Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Isn't the 114 code also caused by a bad shuttle valve switch? When my switch failed, it was a bad solder joint. I carefully disassembled the switch, resoldered and put it back together. It's been over a year with no problems.
My point is just that it could possibly be a bad switch as well. So, be sure to test the stitch while you have it apart.
When I fixed my switch I went ahead and did the option B fix also just to be sure. I figured it was only a matter of time, so I might was well do it.
.Alan.
05-11-2014 08:16 PM
