4 service engine codes...need your help!
hey guys. have an 03 disco with 101,000 mi. service engine light recently came on. here are the codes i pulled.
P 1412
1415
0308 (this code showed up twice for some reason)
0300
please help me out guys! i am a total rookie with auto mechanics. what do these codes mean? which ones require immediate attention? also, any ideas on repair costs (again, im a rookie, these repairs will be done by a mechanic, not myself). i also want to note that the first time the light showed up (came on immediately after i started the disco, still in park) the SES light flashed/blinked maybe 8-10 times, it hadn't been drove for about 2 weeks. i have maybe drove it 5 miles since the light showed up it has not flashed again. I REALLY APPRECIATE ANY HELP GUYS! THANKS!
P 1412
1415
0300
P 1412
1415
0300
P 1412
1415
0300
308 misfire cylinder 8
1412 sounds familiar maybe another one I've run into in the past too.. I'm THINKING the codes that led me to change out the Mass Airflow Sensor?? That was a part of my Three Amigos issue.
I had the 300 codes, and the intermittent blinking/ solid on Service Engine light.. the changing of the plugs and wires fixed it.
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test)
P1415 Secondary Air Injection System – Malfunction Bank 2 RH (Insufficient SAI flow
P0308 Cylinder 8 misfire detected Excess emissions level of misfire detected on cylinder
No.8
Assuming you also got P1308 No description Catalyst damaging level of misfire detected on cylinder
No.8
P0300 Random/multiple cylinder misfire detected Excess emissions level of misfire on more than one
cylinder
So you have an SAI issue, check the connections and also a misfire on 8. When was your last real tuneup?
No.8
No.8
cylinder
Yes that is normal when the engine is cold. I believe the SAI is on the USA passenger (right) side and there is a pump, selenoid, and valve and a bunch of lines that feed in to the head. Follow the lines and make sure everything is connected first. For reference here are the parts to look for:
http://www.RoverParts.com/Nxt/search...ords=secondary
Except that with those codes your engine is running super rich and you are getting (even more) terrible gas mileage.
