4 service engine codes...need your help!
Old May 18, 2010 | 05:45 PM
morzy41's Avatar
Default 4 service engine codes...need your help!
hey guys. have an 03 disco with 101,000 mi. service engine light recently came on. here are the codes i pulled.
P 1412
1415
0308 (this code showed up twice for some reason)
0300
please help me out guys! i am a total rookie with auto mechanics. what do these codes mean? which ones require immediate attention? also, any ideas on repair costs (again, im a rookie, these repairs will be done by a mechanic, not myself). i also want to note that the first time the light showed up (came on immediately after i started the disco, still in park) the SES light flashed/blinked maybe 8-10 times, it hadn't been drove for about 2 weeks. i have maybe drove it 5 miles since the light showed up it has not flashed again. I REALLY APPRECIATE ANY HELP GUYS! THANKS!
Old May 18, 2010 | 06:23 PM
itsbob's Avatar
P 1412
1415
0300
300 Misfire multiple cylinders
308 misfire cylinder 8
1412 sounds familiar maybe another one I've run into in the past too.. I'm THINKING the codes that led me to change out the Mass Airflow Sensor?? That was a part of my Three Amigos issue.
I had the 300 codes, and the intermittent blinking/ solid on Service Engine light.. the changing of the plugs and wires fixed it.
Old May 18, 2010 | 06:26 PM
lipadj46's Avatar
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test)
P1415 Secondary Air Injection System – Malfunction Bank 2 RH (Insufficient SAI flow
P0308 Cylinder 8 misfire detected Excess emissions level of misfire detected on cylinder
No.8
Assuming you also got P1308 No description Catalyst damaging level of misfire detected on cylinder
No.8
P0300 Random/multiple cylinder misfire detected Excess emissions level of misfire on more than one
cylinder
So you have an SAI issue, check the connections and also a misfire on 8. When was your last real tuneup?
Old May 18, 2010 | 10:11 PM
morzy41's Avatar
is the SAI pump what is making the loud (sounds like a fan) noise for 30-45 seconds from a cold start? ive noticed this happens only when the vehicle is un-driven for 5+hours
Old May 19, 2010 | 06:53 AM
lipadj46's Avatar
Yes that is normal when the engine is cold. I believe the SAI is on the USA passenger (right) side and there is a pump, selenoid, and valve and a bunch of lines that feed in to the head. Follow the lines and make sure everything is connected first. For reference here are the parts to look for:
http://www.RoverParts.com/Nxt/search...ords=secondary
Old May 19, 2010 | 08:18 AM
So start with the basics, when was it last tuned along with new 8 mm plug wires and what octane gas are you using?
As for the 2 1400 codes, find a mechanic who is familiar with the SAI system, try to stay away from the dealer.
Old May 19, 2010 | 10:50 AM
r.pollreis's Avatar
3rd Gear
I have an 03 D2 and have my share of codes. I have had P0150 P0174 P1174 and P1415. Seems like these things are a code nightmare but dammit they look and drive good. I am not sure how to start a thread on here
Old May 19, 2010 | 03:17 PM
morzy41's Avatar
My local shop quoted me $350 JUST IN LABOR to replace spark plugs and wires!!! Am I crazy or does this seem very high? This price doesn't even include parts!
Old May 19, 2010 | 04:15 PM
lipadj46's Avatar
Except that with those codes your engine is running super rich and you are getting (even more) terrible gas mileage.
Old May 19, 2010 | 04:16 PM
lipadj46's Avatar
my local shop quoted me $350 just in labor to replace spark plugs and wires!!! Am i crazy or does this seem very high? This price doesn't even include parts!
diy...
