400 miles and only 4 monitors ready?
Old Dec 27, 2010 | 02:41 PM
iownme's Avatar
Default 400 miles and only 4 monitors ready?
happy holidaze to you all!
still trying to get all moitors ready for inspection.
I replaced the 2 front o2 sensors, all monitors ready in 100 miles...
just for fun i put in the old sensor to double check its condition.
threw o2 codes, so i cleared OBD2 and put the new sensor back in.
now i've done 400 miles and only 4 monitors are ready.
IS THIS NORMAL?
new bosch 4 plugs, wires replaced 8 months ago, seafoamed through
induction port
No pending codes....no other codes...MIL (CEL) off
been checking all codes while driving often...no sign of even a pending
code.
Driven the 400 miles in one week...interstate, back roads, mountain
roads, all speeds.....
Old Dec 27, 2010 | 03:31 PM
lipadj46's Avatar
How many times have you started the truck in that time, at least 10 times?
Old Dec 27, 2010 | 05:14 PM
iownme's Avatar
at least!...i've been driving it for about 2 hours a day, stopping and starting for a week now...and all this driving is just to get the monitors ready...it's not driving that i need to do...this is getting expensive at $3.55 a gallon !
Old Dec 28, 2010 | 04:21 PM
iownme's Avatar
anyone out there?
Old Dec 28, 2010 | 05:48 PM
lipadj46's Avatar
I'm not sure the exact drive cycle but in general to get the monitors ready to start your engine 10-20 times and drive 100 miles. Your truck must be upset you put the bad O2 sensor back in. Is it an O2 sensor monitor that is not ready?
Old Dec 28, 2010 | 07:28 PM
lordmorpheus's Avatar
 Drive cycle A:
1 Switch on the ignition for 30 seconds.
2 Ensure engine coolant temperature is less than 60C (140F).
3 Start the engine and allow to idle for 2 minutes.
4 Connect TestBook and check for fault codes.
 Drive cycle B:
1 Switch ignition on for 30 seconds.
4 Perform 2 light accelerations (0 to 35 mph (0 to 60 km/h) with light pedal pressure).
5 Perform 2 medium accelerations (0 to 45 mph (0 to 70 km/h) with moderate pedal pressure).
6 Perform 2 hard accelerations (0 to 55 mph (0 to 90 km/h) with heavy pedal pressure).
7 Allow engine to idle for 2 minutes.
8 Connect TestBook and with the engine still running, check for fault codes.
 Drive cycle C:
7 Cruise at 60 mph (100 km/h) for 8 minutes.
8 Cruise at 50 mph (80 km/h) for 3 minutes.
9 Allow engine to idle for 3 minutes.
10 Connect TestBook and with the engine still running, check for fault codes.
NOTE: The following areas have an associated readiness test which must be flagged as complete, before a problem
resolution can be verified:
l catalytic converter fault;
l Evaporative loss system fault;
l HO2 sensor fault;
l HO2 sensor heater fault.
When carrying out a drive cycle C to determine a fault in any of the above areas, select the readiness test icon to
verify that the test has been flagged as complete.
 Drive cycle D:
2 Ensure engine coolant temperature is less than 35C (95F).
7 Cruise at 60 mph (100 km/h) for 5 minutes.
8 Cruise at 50 mph (80 km/h) for 5 minutes.
9 Cruise at 35 mph (60 km/h) for 5 minutes.
10 Allow engine to idle for 2 minutes.
11 Connect TestBook and check for fault codes.
 Drive cycle E:
1 Ensure fuel tank is at least a quarter full.
2 Carry out Drive Cycle A.
3 Switch off ignition.
4 Leave vehicle undisturbed for 20 minutes.
5 Switch on ignition.
6 Connect TestBook and check for fault codes.
Unfortunately, LR is rather vague about which of the 5 different drive cycles are needed to run various monitor tests.
Old Dec 28, 2010 | 07:53 PM
iownme's Avatar
i called a local LR mechanic i'm friendly with, he suggested disconnecting the battery and holding the battery wires together to do a "hard reset"
i did that this afternoon so i'll just keep driving now and see what happens.
Something just does not feel right about this.
The monitors not ready are, 02, catalyst and evap
would have to happen in roadblock season (cheesy lol)
hopefully if i get stopped by cops they will see my obd2 reader plugged in and let me go , fine free. Time to go for a drive i guess.
Thanks for the drive cycle info...too bad i just sold my 10 mile private road :+)
Old Dec 28, 2010 | 07:58 PM
iownme's Avatar
and for any others having inspection/monitor ready issues....
your post 2000 car can have 1 monitor not ready and still pass inspection....pre 2000 i hear can have 2 monitors not ready...tho i've not double checked the 2 monitor regulations. Most shops won't tell you that for some reason
Old Dec 28, 2010 | 11:47 PM
oysterhead's Avatar
What are monitors?
Old Dec 29, 2010 | 05:38 AM
lipadj46's Avatar
Originally Posted by oysterhead
What are monitors?
Your truck's ODBII emissions monitors that get read to pass inspection.
