4HP22 Normal Operation
Old Apr 11, 2023 | 08:46 AM
adalton's Avatar
Default 4HP22 Normal Operation
Hi everyone,
I am curious to know the normal functionality of the ZF 4HP22 transmissions in our trucks. Is it normal for the torque converter to be heard when shifting from 1st to 2nd? Sometimes when shifting when the engine and transmission are cold it shifts very slowly, but when warmed up it does not. Also, is 3000 rpm normal when going 80 mph?
Old Apr 11, 2023 | 10:04 AM
jastutte's Avatar
tire size will affect RPMs at a given speed. what size tires are you running?
Old Apr 11, 2023 | 06:53 PM
Extinct's Avatar
3000 at 80 is pretty close to normal, you should be able to notice rpm drop for each gear shift as well as torque converter lockup.
Old Apr 12, 2023 | 01:48 PM
ahab's Avatar
Might want to see if the trans will take any fluid. Or drain what you can and refill till it starts running out the fill hole.
V8AUTO
Feb 15, 2023 01:56 PM
DCYH
May 27, 2018 08:11 AM
EstorilM
Dec 18, 2010 11:00 AM
tomfraser
Jan 27, 2009 06:34 PM
LambChop
Dec 15, 2008 09:35 PM
