300TDI ZF Auto
Old May 26, 2018 | 09:03 AM
DCYH's Avatar
Default 300TDI ZF Auto
Hi all. I have a 300TDI Discovery fitted with ZF automatic transmission. The engine RPM will drop tremendously i.e. from 3000RPM to 1800RPM when the gear shift from 3rd to 4th. The RPM then slowly creep up from 1800RPM to more than 2500RPM then only I can accelerate again. To over come it, I usually manually shift it to 3rd, picks up enough speed and RPM then only manually shift it to 4th.
Please advise what is wrong. Thank you in advance.
Old May 27, 2018 | 08:11 AM
ihscouts's Avatar
Might be torque converter or direct drive clutch or its control valve. In 3rd the trans and engine are locked at 1:1 ratio, in 4th the torque converter is supposed to disengage, sounds like it isn't initially.
raro88
Jul 11, 2014 10:19 AM
flashman.tv
Aug 18, 2013 09:19 AM
Mart 678
Dec 3, 2012 01:56 PM
Benjamin Wright
May 13, 2012 04:40 PM
The Devil Made Me Do It
Jun 16, 2011 01:38 PM
