4wd
first thing is your truck is 4wd. there is no shifting in to 4wd. most likely the hi-lo has not been used and thats why it is so hard to get into the low. you can pop the boot and spray the crap out of it with some penetrating spray and see if you can work it till it comes into function again. you can only shift when in neutral and not moving.
You have to be moving at about 5 mph in neutral. If your stopped and trying to shift a rarely used transfer box, IT WONT WORK.
crawl in drive (without apply gas) on a level surface, shift to N without touching brake. Make sure the Speedo isnt regestering anything. Then shift the Transfer box to L.
I cant believe no one else caught this?
