Is 5 PSI a problem
Hello all, I have a 2003 Discovery SE with 75,763mi. One day it started making this kind of muffled ticking noise and since my VIN is within the recall range for the oil pump failure, I got a little nervous, so I installed an oil pressure gauge today, however when idling the PSI drops to 5-PSI but between 2000 and 2500 it is 46 to 51 PSI. Is the 5 PSI a problem for me, enough to cause me to consider replacing the oil pump now?
Thanks
Round Hill Rover
Thanks
Round Hill Rover
5 PSI is way to low.... I would bet that your oil pump is probably cracked and starting to loose its "umpff". If you could replace it now before it becomes a complete engine replacement I would. OR at least keep the RPMS up high when your driving in the city and get a dreaded red light...
The light doesn't come on until 3-8.5 psi. Minimum at idle should be 10psi, minimum.
By 2K you should have steady pressure at 50 give or take a little because of pressure relief valve tolerances but steady.
The light is pretty worthless, the sound of the engine tells you you've an issue before the light pops on. Generally by the time the light's on it's all over.
It could be the gauge though, generally unless it's a very top quality gauge the accuracy falls way way off at the low and high ends. Either way it needs looking into.
Sure do and you'll have to remove the transmission cooler stays so you can move the lines out of the way to get to a few of the bolts. If the pan doesn't easily drop, you've missed a bolt or two. Also don't forget about the oil pickup, it can be easily bent if you're not careful.
The up-side is you don't have to worry about fooling with oil cooler lines.
It's not that terrible of a job but I'd verify pressure with another gauge if you haven't already, could save you some hassle. If you installed a mechanical gauge make sure there aren't any kinks in the line etc.
