6.5 inch speaker wiring harnesses
Old Jan 28, 2013 | 07:53 PM
spazmoid's Avatar
Default 6.5 inch speaker wiring harnesses
I'd like to replace the 6.5" speakers in each door but I'm having trouble finding the correct wiring harness. Crutchfield lists this Speaker Wiring Harnesses For select 1978-up vehicles at Crutchfield.com but that connector is definitely not correct. I have a picture of the plug in the front door and it looks nothing like the one on Crutchfield. Has anyone come across the correct harness? I know I can just cut and splice the wires but I'd rather go plug and play if possible. Thanks
Old Jan 28, 2013 | 08:25 PM
aarongregor's Avatar
I re did mine in my 03 and and did the cut solder and heat shrink method. Super easy man. Save the cash and use your hands.
Old Jan 28, 2013 | 08:57 PM
Michael M. Koch's Avatar
Or just get some red butt splices, no worries about accidentally burning your door panels. Or yourself.
Old Jan 29, 2013 | 06:08 AM
04duxlr's Avatar
I went the cut and solder route. Butt connectors work but I prefer solder because it will never fail. If you are worried about being able to return it to stock, just cut the wires back far enough to allow the plug to be reconnected but honestly, you will never put the factory junk back in. Just cut, splice and rock.
bamaboy473
May 16, 2012 06:57 AM
Joebern
Jun 21, 2011 05:09 PM
turf63
Audio/Visual Electronics
Jul 10, 2010 11:33 AM
zracin
Feb 21, 2008 03:39 PM
morfa
Aug 27, 2006 01:22 PM
