60K check up
60K check up
The 2001 Disco I just bought is a couple of thousand miles away from the 60K tune-up/maintenance check. I phoned the nearest LR dealer (not very convenient ...1 1/2 hours away) to inquire about cost. $1000.
In the owner's manual, there isn't a listing of what this stage tune up consists of and I'd really like to know. There are local mechanics who can work on LRs just fine.
For this first major one, should I go to a dealer or should I stay local. Thoughts?
Thanks!
Thanks!
on
RE: 60K check up
ORIGINAL: vicki2
Well, except that one has a computer and one didn't lol. Also, the Series I never reached 60K!
Is there an online site where I can review all the components of the 60K as a list? Thanks.
Here is a list I put together for a major like a 60K.
Mike
This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transsmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both od the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
