60K Service and more for used vehicles
Old Sep 2, 2009 | 11:42 AM
  #61
antichrist's Avatar
Originally Posted by demonlarry
the transmission fluid change, are you talking about an A/T or manual transmission?
Always good to put what you have in your sig (see mine as an example), or at least in your profile.
Makes it a lot easier to answer questions.
If you have an R380, the 5-speed, you need 2.8 qts of Redline MTL for the main gearbox.
Also, a lot of people complain of problems running platinum plugs in D1's.
Old Sep 2, 2009 | 09:41 PM
  #62
demonlarry's Avatar
I run NGK in EVERYTHING. I love them. I'm putting them in the Disco on monday.
BPR6ES
i changed my signature by the way
Old Oct 1, 2009 | 01:33 PM
  #63
Aj6543's Avatar
Can somone post how often these check-ups are needed to be done for each item? ie: every 20K- Every oil change?
Old Oct 4, 2009 | 01:23 PM
  #64
oldcase's Avatar
I recently purchased a 95 Disco with 81k. It has the 5 speed. I changed the fluids and put a synthetic ATF in the 5 speed. Is there a service bulletin from Land Rover on using something else? My service manual says to use ATF.
I want this vehicle to last a long time and want to use the proper fluids.
Thanks,
George
Old Oct 4, 2009 | 05:16 PM
  #65
antichrist's Avatar
You should be using MTF in the R380.
Redline MTL is the lube of choice.
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Old Oct 4, 2009 | 06:50 PM
  #66
oldcase's Avatar
Thanks for the input. I will order it and change the transmission oil again.
George
Old Oct 5, 2009 | 06:57 AM
  #67
antichrist's Avatar
Check some local speed shops, they often carry Redline.
Old Dec 14, 2009 | 02:52 PM
  #68
Mrmerlin's Avatar
Josh, I saw your sequence of things you do.
I would suggest that you do the Oil change after
you do the intake cleaning and after you run a few bottles of Techron through the engine fuel system, this will remove as much loose dirt as possible.
No need to contaminate your fresh oil with intake contaminents
Old Jan 7, 2010 | 02:40 PM
  #69
G4AKumar's Avatar
Originally Posted by Disco Mike
1 Oil filter, K&N 3001 or Mobil 1- 301
8 Spark Plugs, I use Bosch Platinum Plus 4's.
Disco Mike-- what do you think of the Bosch Platinum IR Fusion? (http://www.boschautoparts.com/Vehicl...CAT=SparkPlugs) Would love your input... cheers
Old Jan 7, 2010 | 03:45 PM
  #70
hilltoppersx's Avatar
never heard of those till now that could solve the forums everlasting debate or Iridiums vs +4's!!!!
