75k Mile Service
Old Oct 1, 2010 | 01:18 PM
rbwdriven's Avatar
Default 75k Mile Service
Ok so my 2001 Disco SE7 has finally hit 75k.
According to the dealer manual there is a 75k service on it.
What should I be doing?
I've already done the gospel 60k service on it.
Since the 60k service I've also redone the following.
front and rear brake pads.
front and rear rotors
total rebuild on front drive shaft including new pivot ball bearing and boot.
I'm also a proud new owner of a abs amigo tool as well since the first two changes that triggered the three amigos.
What else should I do?
I'm thinking at least oil change.
I'm planning on dropping the oil pan due to a slight leak so I'm going to replace the gasket at the same time.
Thanks
Richard
Old Oct 1, 2010 | 02:22 PM
hilltoppersx's Avatar
did you service the tranny at the 60k service?
Old Oct 1, 2010 | 02:32 PM
lipadj46's Avatar
From your post it sounds like you have not changed your oil in 15k miles.
Old Oct 1, 2010 | 02:39 PM
yloDiscoII's Avatar
That's exactly what I was thinking....
Old Oct 1, 2010 | 03:35 PM
If you did a full blown 60K with all fluids being replaced and a complete tune up including new 8mm silicone plug wires, then all you need to do is a visual inspection and oil/filter, what are you using for your oil and filter?
Old Oct 2, 2010 | 07:49 AM
rbwdriven's Avatar
Default tune up
I actually using sythetic motor oil that you recommended and also the long LR oil filter.
Yes I did the complete tune up per your recommendations.
I forgot to put in the folloowing.
I also did the throttle body heater plate
new intake manifold gasket
new throttle body gasket.
Pretty much I've been around LR's all my life so this thing gets a monthly nut and bolt check any way.
Thanks
BuffaloDisco
Nov 1, 2011 02:09 PM
StevenDiscoII
Aug 7, 2009 08:18 AM
dms98e
Jul 3, 2008 07:52 PM
lbeamon
May 29, 2008 09:25 PM
rover2003
Jan 28, 2008 11:08 AM
