7mm v 8mm wires
Old Nov 26, 2010 | 11:06 AM
iownme's Avatar
Default 7mm v 8mm wires
i just went to Atlantic British to order 8mm magnecor wires (as per everyone heres suggestion) and was told they don't stock OR recommend using them.
the reason given is that they do not fit inside the wire holder correctly and can pinch the wire.
surely if the 7mm are good enough for Mr landrover (corp) why do people here INSIST on changing to 8mm. I'm not looking for any power increase. just want to replace, as the current wires are not in great shape.
Can you shed some light on this for me?
Old Nov 26, 2010 | 12:00 PM
NiteTrain's Avatar
they are correct..they do not fit in the wire holders. Do you want a spark plug wire that gives you a better spark, more power and last longer or do you want one that fits in the factory holder?
Old Nov 26, 2010 | 12:40 PM
yloDiscoII's Avatar
The 8mm wires also handle the heat of the engine better. Your engine will perform just fine with 7mm wires, it will just perform better with 8mm wires.
Old Nov 26, 2010 | 01:12 PM
buick215's Avatar
They are right, the 8mm spark plug wires don't fit in the holders but I still prefer them. The 7mm wires that come from the factory don't hold up to the heat in the engine bay and have to be replace more often. Our engines run hotter than most automobile engines.
Old Nov 26, 2010 | 01:16 PM
iownme's Avatar
so with this logic why not upgrade to 8.5mm instead of 8mm?...magnecor make both
Old Nov 26, 2010 | 01:20 PM
iownme's Avatar
found mag 8mm for $98 + shipping
8.5mm for $128
Old Nov 26, 2010 | 01:21 PM
iownme's Avatar
"They are right, the 8mm spark plug wires don't fit in the holders but I still prefer them"
so did you buy new holders or just jam the wires in the old holder?
Old Nov 26, 2010 | 01:36 PM
buick215's Avatar
7mm is to small and 8.5mm is a little over kill in my opinion. If you try to put the 8mm wires in the plastic holders you could break them or worse damage the insulation on the wires. I would just leave them loose, I think that is what most people do.
Old Nov 26, 2010 | 03:30 PM
bosshogt's Avatar
I have magnecore 8mm and they fit fine in the holders. I just used a little dieletic grease and they snapped right in. They have been installed for 1.5 years and been great. I double checked the original box and and they are the 8mm for sure. I have a 2003 maybe the holders on newer models are larger...just a guess.
Old Nov 26, 2010 | 04:35 PM
SDinDS's Avatar
My 8mm wires also fit in the holders. I think it's because all that heat under the hood has made the holders expand!
Eric
