7mm v 8mm wires
Old Nov 26, 2010 | 04:38 PM
Personally I dont think 1mm makes one hell of any difference, I mean really? Do you know how small 1mm is?
That being said I have the 8mm wires because they were only $5 more so why not?
Old Nov 26, 2010 | 04:53 PM
I can send you a picture showing that my 8mm wires fit just fine in the factory wire holders.
You can also use the 8mm STI wires from British Parts of Utah for $70 a set.
Old Nov 26, 2010 | 10:25 PM
antichrist's Avatar
Originally Posted by iownme
i just went to Atlantic British to order 8mm magnecor wires (as per everyone heres suggestion)
Not everyone.
I've switched from Magnecore to Kingsborne, 1/2 the price for good wires.
They also sell wire separators that 8mm fit well in.
Wires
http://www.kingsbornewires.com/produ...&categoryId=38
Separators
http://www.kingsbornewires.com/categ...?categoryId=88
Old Nov 27, 2010 | 08:20 AM
iownme's Avatar
WOW!!...even less than half....$35 for 8mm.
are they working well for you?
it says they have screw on coil connectors...do the LR wires screw on or push on?...i know they have "ridges" , i thought this was for a good fit...not sure if i should have "screwed" them on.
thanks muchly for the link...i may go with these....$ is an important factor for me now.....in the "ole days" i just used to buy the most expensive...DUH!
Old Nov 27, 2010 | 08:32 AM
iownme's Avatar
just ordered 8mm yellow + wire holders....with shipping total was $56.
thanks again for the link...very kind!
Old Nov 27, 2010 | 08:36 AM
SDinDS's Avatar
No, they just push on. I've got the Kingsborn wires and no problems so far.
Eric
Old Nov 27, 2010 | 06:48 PM
roverintherocks's Avatar
I have had the Kingsborne 8mm and the STI 7mm honestly I prefer the STI I noticed that the Kings had given me an odd radio wine... The 1mm difference is not enough to matter in our motors... Now on my Corvette I run 10.5 Taylors but that is a high compression fire breathing bad ***... The Rover is just a daily driver with the capabilities to do much more... lol...
On the 8mm point also I work for a Rover repair shop in Denver and we have had many trucks come in with 8mm wires that for some reason or another are arcing and I have never seen a 7mm wire come in with that issue... Actually we have swapped wires on many Rovers from the 8mm to the 7mm just testing because there is a missfire and that has solved many of those customers problems... Just something to think about...
Old Nov 27, 2010 | 07:59 PM
This is VERY valuable info in only we could prove it.
Many many many many people have done a complete tune up on their DII and afterwards have a mis fire that cannot be solved.
They always leave the forum to never be heard from again after replacing the coils and having the problem remain.
Old Nov 27, 2010 | 09:09 PM
antichrist's Avatar
I can't see any reason an 8mm would cause a problem where a 7mm wouldn't, comparing the same brand.
I can see where 8mm might come loose from the separators and lay against metal parts and/or each other and leak current.
Old Nov 27, 2010 | 10:07 PM
iownme's Avatar
maybe you get many customers having problems with the 8mm because they are forcing them into the 7mm holders, i like the idea in this thread with using dielectric grease to ease them in, but i still prefer a "correct" fit, so i just bought the correct holders.
