7mm vs. 8mm spark plug wires
Old Sep 13, 2012 | 05:04 PM
Joshman's Avatar
Default 7mm vs. 8mm spark plug wires
Rock auto has NGK and other wire sets in 7mm for under $25, whereas the Magnecor 8mm wire sets I see are at least $80. Since Rock Auto only sells 7mm wires for the Disco 2, would swapping out my old wires for 7mm wires be bad? thanks guys.
Old Sep 13, 2012 | 05:22 PM
0304Disco's Avatar
Just ordered a set of kings born 8mm for $30/$40 to my door. Have them on my 04' disco and have no issues.
Old Sep 13, 2012 | 06:15 PM
coors's Avatar
Care to share with us where you made this fine purchase...
Old Sep 13, 2012 | 07:28 PM
8 mm silicone wires are a must if you don't want to change them again, and believe ,e you won't want to do it again.
My Magnecores are now 10 years old and have held up to the crazy heat issues in our Disco engine compartments.
Old Sep 13, 2012 | 08:34 PM
Discosomewhat's Avatar
FYI, the Bosch replacements are 7mm. I just put a set on this evening and it was a lovely experience.
Old Sep 13, 2012 | 08:54 PM
Rover De Land's Avatar
NO... You really think .5mm in each side of going to same the day? It won't, what's far more important is wire construction. Don't buy say autozone duralasts, the caps pop off.
Old Sep 13, 2012 | 09:24 PM
Antmen's Avatar
You're right - the quality of the cable (both conductor and insulator) is a factor. But, I know in terms of Magnecor, it's not only the insulation that is thicker; It's the conductor which is thicker, as well. When multiplied per cm (remember you can't just compare a cross section of .05mm when speaking of the entire length of a cable,) it allows for higher conduction / less resistance.
Old Sep 13, 2012 | 09:32 PM
0304Disco's Avatar
Kingsborne.com
Old Sep 13, 2012 | 09:41 PM
jpmiller's Avatar
I have to give my $.02 on this. Bought a set of magnecor 7mm's and was not impressed with the quality vs. price. They seemed a little on the short side and I had to replace one. My next go around I ordered a set of 8mm Kingsborne's and asked them to add 2" to the length. They did so without extra charge. The coil end of the plug is numbered so it made it easy to match to coil order. So far, I have been very happy with the Kinngbornes and feel that the quality, price, and service have been spot on.
Old Sep 13, 2012 | 11:49 PM
I just want to remind people these are land rovers, you can buy the best most expensive everything but it won't change a thing.
