95 D1 lift questions
Old Mar 4, 2010 | 10:14 PM
Backpoints's Avatar
Default 95 D1 lift questions
Im getting ready to buy an OME 2.5" lift for my D1. Do I need to extend the brake lines and do I need a dropped pitman arm?
Old Mar 5, 2010 | 12:09 AM
demonlarry's Avatar
I'm doing the brake hoses on mine. I've a 95 and I'm only doing a 1" lift.
I'm basically doing it on age and mileage.
Dropped pittman arm, I dunno if it's required or not.
Old Mar 5, 2010 | 08:12 AM
hilltoppersx's Avatar
3" is about the limit for lift before the lines NEED to be replaced but you should replace them anyway while you are there. there are some nice steel ones.
Old Mar 5, 2010 | 11:24 AM
Long Haul's Avatar
My 99 D1 is lifted 3" and all i needed was longer brake lines. Definatly get stainless steel the disco will stop a lot better than the rubber hoses. As far as pitman arm im still running stock but you might want to look into offset caster swival joints. It drives fine without them but im noticing more tire wear.
Old Mar 5, 2010 | 11:46 AM
AK Rover's Avatar
I ran the OME HD lift on my 97 with factory brake lines without a problem. I would advise going to the stainless lines whether stock length or extended since your factory rubber lines have expanded and aren't getting as much pressure to the caliper.
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
