95 Discovery (black) - Boiling
Old Aug 17, 2009 | 09:43 PM
If the test comes back negative then you do not have cancer.
mattrickman's Avatar
Does anyone have a good suggestion for a place to buy a coolant system pressure tester? Does the Craftsman version work with a disco's cap??
thanks
Old Aug 17, 2009 | 09:58 PM
As long as you have the right adapter any coolant psi tester will work, even the one that you can "borrow" from AutoZone with their "loan a tool program".
Old Aug 26, 2009 | 04:43 PM
Finally got the new reservoir and cap from Atlantic British (wow, they sure hammer you on shipping...)
Problem is now solved. So replacing the Radiator and getting a non-leaking reservoir solved the problem.
Swapping the radiators was a pretty easy job, the bottom hose is a PITA to get off, but other than that, very easy.
Old Aug 26, 2009 | 04:50 PM
AK Rover's Avatar
Swapping a radiator in these trucks would be a lot easier if the engineers at Rover had thought to put a petcock in the bottom to drain it. ( Yes, I could have said valve but petcock sounds funnier.)
Old Aug 26, 2009 | 05:33 PM
hilltoppersx's Avatar
thank god..
Twncty2
Apr 21, 2013 08:01 PM
blast20
Jul 16, 2011 09:32 PM
lbrover
May 31, 2010 05:00 AM
bigfun
Dec 13, 2007 04:23 PM
