96 Disco brakes
Old Jan 24, 2009 | 08:22 PM
jbriggs's Avatar
Default 96 Disco brakes
Changing the brakes onmy Rover and this is the first time for me. Do you really have to pull the axel shaft out on the rear brakes? Are the rotors pressed onto the hubs? Thanks.
Old Jan 24, 2009 | 09:25 PM
Default RE: 96 Disco brakes
I do not know that answer, sorry.
Check the Rave manual.
Old Jan 24, 2009 | 09:36 PM
llPANCHOll's Avatar
Rave Manual Link
Old Jan 24, 2009 | 09:54 PM
jbriggs's Avatar
Thanks. Yes the axel comes out. Crapload of work to change brakes.
Old Jan 24, 2009 | 10:05 PM
Only if you are changing the rotors though. Dont need to for the pads.
Old Jan 24, 2009 | 10:08 PM
llPANCHOll's Avatar
ORIGINAL: Spike555
What he said..
Are your rears Chewed up??
Old Jan 25, 2009 | 01:48 AM
NiteTrain's Avatar
finally! one thing where DIIs are better.
Old Jan 25, 2009 | 11:33 AM
jbriggs's Avatar
The front are good, just need pads, the rears are gone, rotors are trashed. I was told the rotors are pressed onto the hub, does anyone know if that is true?
Old Jan 25, 2009 | 11:41 AM
llesra's Avatar
i dont think they are pressed on. atleast mine werent. the two are probably rusted together though.
while you have the hub out, might as well change the wheel bearings.
Old Jan 25, 2009 | 12:01 PM
llPANCHOll's Avatar
ORIGINAL: llesra
Now this advice about the changing out the rear bearings while you are in there..
I would take it..
This looks to be about a 6.5 on the PITA scale, so why not just do the bearings while you are there, just for peace of mind.
Ok look at the Rave manual..
PAGE 476 and 477 of the WORKSHOP Manual
It does state that the real axle must be removed to to get to the bolts that hold the rotor on the hub.
Now odds are the tolerances are pretty tight..
It does not however say anything about "PRESSING" the rotor on or off..
It might take a Wooden Mallet..
It might take a Machine Shop...
Let us know how it turns out..
