96 discovery misfire?
Old Apr 1, 2008 | 11:00 AM
jsh's Avatar
jsh
4wd High
Default 96 discovery misfire?
Hi guy's:
I have a 96 discovery w/95,000km's
The vehicle is new to me. I bought it cheap w/ a check engine light on and error codes: PO304B and P1316.
Plugs,wires,O2 sensors and Coil packs replaced.
Check engine light off and major misfire and loss of power is fixed.
Problem: At highway speeds100 kmph going up hills the engine feels like misfire - ie: vibration at a constant frequency and magnitude. Slight throttle adjustment (up or down) and the vibration clears right up. There are no error codes generated.
Are there further ignition components that I should pay attention to or could this be a fuel management problem.
This is my first land rover and I really like the vehicle and if when this is sorted out it will be a great vehicle.
Any help is appreciated
thanks
john
Old Apr 1, 2008 | 01:18 PM
Landzu's Avatar
Default RE: 96 discovery misfire?
Start checking for vacuum leaks,, look around the intake and the vacuum line going to the fuel regulator (just to the back of the intake left side).
Go to auto zone and get them to read the codes or better yet get a OBDII code reader $60 C.D.
Goog luck with your Rover!!!!!!
Old Apr 1, 2008 | 03:11 PM
taskforce121's Avatar
You should probably look to swap out the VSS, that may be the source or your misfires at speed.
phil
94 and 97 Disco I
Old Apr 1, 2008 | 05:20 PM
He probally doesnt have a AutoZone in Canada.
I would have to agree that it is your Vehicle Speed Sensor.
It cuts power to the engine so you cant go to fast (110 mph), when it goes bad it will do it even when not going to fast.
Go to www.discoweb.org and look at the tech page and you will see how to replace it.
Old Apr 1, 2008 | 06:40 PM
jsh's Avatar
jsh
4wd High
Thanks for the replies.
I will look into vacumn leaks and the VSS
I will re post as situation warrants.
john
Gromeo
Jan 24, 2013 03:41 PM
borntojump
Aug 31, 2008 12:41 PM
Sport4Auto
Feb 27, 2007 06:52 PM
lajilana
Sep 2, 2006 10:47 AM
Scott2747
Feb 8, 2006 12:11 AM
