96 Discovery SE7 Front Wipers
Hello all,
I just recently had a problem with my driverside wiper. When I turn them on the driverside wiper doesnt move except for a little motion in time with the passenger side wiper. Based on this I think the motor is running fine but something is just not catching (sorry for the lack of technical nomenclature) so the driverside wiper is not moving. I have zero understanding of what actually makes up a wiper assemply but Im hoping there is just a worn part or something needs to be tightened down instead of a complete replacement.
I have a 96 Discovery I SE7. I appreciate any help.
Thanks!
Thanks!
The first thing you want to do is make sure the arm is actually tight on the splined pivot it is attached to. There is a nut that locates the arm on the tapered spline. It may have backed out. You have to gently pry the plastic cover up to gain access to the nut.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
Glad I could help!
Arm yourself!-- read my tech info pages at www.eurotekapg.com to get a primer on your Land Rover. We've been "living" with these vehicles for more than a few years now, and the tips, hints, and advice contained on the site will assist you in the future.
regards,
Geoman
regards,
Geoman
