97 with code P0300, P0303, P1314, P1313 runs rough What could it be?
Old May 16, 2009 | 06:26 PM
twilightcall's Avatar
4wd High
Default 97 with code P0300, P0303, P1314, P1313 runs rough What could it be?
My friend has a 97 Rover with a reman engine. He has been getting these codes since it was installed. He had new plugs, wires and coil pack installed at the time the engine was put it. I don't know this car at all other than what he told me. I am trying to help him fix it. Do you think the spark plug wires are crossed or could it possibly be a headgasket leak? He told me he hasn't had to add any coolant to the rover. Should I give it a compression check first or find a copy of the firing order/plug diagram and check it out? Does anyone have a plug diagram? Thanks.
Old May 16, 2009 | 06:31 PM
What plug wires did they use when they put the engien back in the truck?
Old Jul 1, 2020 | 10:31 PM
lakeradio's Avatar
Default Codes p1314 and p1314
My 1998 Discovery shows codes p 1313 and 1314. Runs bad
Did you fix Rover ? What was fix ?
Thanks
lakeradio
teeboli
Dec 13, 2019 10:49 PM
Toran
Sep 14, 2018 08:06 AM
jimbo972
Jul 14, 2010 09:00 PM
jasons
Aug 17, 2009 11:50 PM
lajilana
Sep 2, 2006 10:47 AM
