97 DI Fan removal from water pump
Old Apr 20, 2009 | 11:27 PM
roverohio's Avatar
Default 97 DI Fan removal from water pump
To remove the fan from the water pump is the nut reverse threads? Clockwise or counterclockwise to remove? I have tried and so far it will not break loose.
Old Apr 21, 2009 | 01:05 AM
hazletbassist89's Avatar
it's reverse thread you just need to put a lot of torque on it. get some penetrating lube soaked in it and get a nice wrench with a 2 foot breaker bar and it will break.
Old Apr 21, 2009 | 09:44 AM
roverohio's Avatar
Know what size wrench?
Old Apr 21, 2009 | 09:51 AM
Wildhorse1966's Avatar
32MM wrench
Old Apr 21, 2009 | 10:04 AM
Jawbox's Avatar
It can be ridiculously painful to get loose. If you haven't already, rent the fan clutch kit from your local auto store. (Advance and Autozone return your full deposit when you return the tool) It should include both a holder you wedge between the bolts on the pulley, as well as a wrench that you can put a breaker bar on for extra leverage.
Also, like previously mentioned, put penetrating lubricant on it, every hour on the hour from the morning when you get up, until you finally work on it.
Old Apr 21, 2009 | 10:05 AM
okdiscoguy's Avatar
a well placed chisel on the nut works too, if you are replacing it.
Old Apr 21, 2009 | 03:49 PM
roverohio's Avatar
Thanks guys. Local shop says they will remove for $10..Going there tonight. will update..
Old Apr 21, 2009 | 05:57 PM
twmj1953's Avatar
Default clutch fan removal
I believe that it is regular threaded. I removed both my 96 and 2000 Disco's clutch fan by heating the nut with a propane torch using a wrench on the nut and long screw driver on the pulley. It's best with two persons.
Old Apr 22, 2009 | 08:54 AM
roverohio's Avatar
Shop had it off in minutes. It helps to have the right tools..and no charge...
Old Apr 22, 2009 | 03:46 PM
mrcrptguy's Avatar
I have removed my fan a few times and it is regular lefty loosy righty tighty threads.
