97 DI Fan removal from water pump
Old Apr 22, 2009 | 06:20 PM
SurfRat's Avatar
Originally Posted by mrcrptguy
I have removed my fan a few times and it is regular lefty loosy righty tighty threads.
Absolutely correct. On the D1 (at least my 94 D1) the fan nut goes on via a normal thread rotation. NO REVERSE THREADS. This is when viewing the motor from in front of the grill/radiator. Not sure who started this reverse thread nonsense.
Old Apr 22, 2009 | 10:36 PM
roverohio's Avatar
You guys are correct right tightens / left loosens. New pump on and running good. Lucky no damage was done to engine as old pump came completely apart and belt jumped off. Got a little hot before I could get off freeway..
Old Apr 24, 2009 | 11:18 AM
JerrodSteph's Avatar
I finally got the fan clutch off thanks to this thread, I had read that it was right hand thread on some forums. Nope it comes off the conventional way. Righty tighty lefty loosey. Glad its not destroyed as a result of that wrong info.
Old Feb 24, 2010 | 05:10 PM
ljdiscovery's Avatar
Question Fan Nut on a 99 DI 32 mm?
is the nut that holds the fan to the water pump a 32 mm on the 1999 DI? Thanks Phil
Old Feb 24, 2010 | 06:26 PM
Yes.
All DI's use the same size nut.
I think the DII's use a different size.
Old Feb 25, 2010 | 12:00 AM
Thumbs up Fan Nut Size DI
the fan nut size on a DI is a 36 mm, not a 32 mm converts to a 1 7/16.
Phil
maddisco
Nov 5, 2019 08:51 AM
Frank4
Sep 19, 2010 06:23 PM
rlrigsby
Mar 22, 2010 03:20 PM
SurfRat
Jan 12, 2009 04:20 PM
mooal5
Feb 17, 2008 09:01 AM
