'97 Disco 1 Fails to turn-over & Electrical Probs
RE: '97 Disco 1 Fails to turn-over & Electrical Probs
Read through this, it is for a different car but the same engine and engine managment system.
http://www.gomog.com/allmorgan/GEMS/GEMSbyPoole.pdf
It tells you how to turn the engine over without starting it, there is a button under the hood on the firewall somewhere.
It is there to test compression without cycling the whole ECU.
It is forall GEMS engines. The engine in the link is a 2001, but nothing has changed from then to now. A GEMS is a GEMS. They are pretty bullit proof and simple. Everything has a default mode, so if something fails the engine will still run, might run like crap, but it will get you home.
The only thing without a fault mode is the crank sensor.
That also lists every single fault code in the OBDII system.
If you read the whole thing it will tell you everything you ever wanted to know about the GEMS engine management system.
ORIGINAL: Spike555
I’m so embarrassed, it turns out that it was corrosion on the Positive (+) wire going into the battery terminal. Once I cleaned it up it started no problem. Oh well at least I got to learn all about the alarm & starting systems. Mark G, you are the man!!
Most people learn the hard way (I know I do), now it won't happen again. Thanks for the update. Battery clamps and cable ends are one of those things that should just be replaced every 10 years or so, usually you can't see the corrosion at all.
