97 Disco Oil Leak
Old Sep 3, 2007 | 08:10 PM
ScottMotorsports's Avatar
Default 97 Disco Oil Leak
I have a new to me 97 disco with 110k. Great shape but has a oil leak. I fixed the drain plug leak with a new one. It now has a oil leak that seems to be coming from the Oil filter, drips down from the edge and down the bottom of the filter. I tried to filters a fram and now a bosh, Any ideas?
Old Sep 3, 2007 | 09:06 PM
Default RE: 97 Disco Oil Leak
With the filter off, don't you have a couple bolts that hold the filter housing to the engine, are they loose?
Old Sep 4, 2007 | 10:55 AM
Thanks for the help? I'll pull the filter and check them. Hope I can reuse the filter. Is there a gasket behind there also? This sure seems like it would make it look like a oil filter leak.
Old Sep 4, 2007 | 11:24 AM
okdiscoguy's Avatar
Also check your oil pressure switch. It is right behind it on the block. It will leak down the filter. I just changed mine....same symptoms.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
