'97 Disco Power Window Issue
Old Oct 11, 2009 | 07:19 PM
parajumper's Avatar
Default '97 Disco Power Window Issue
Ok so here's the issue, I tore apart the door to fix the window due to the white washer breaking on the regulator. Well I finally got around to ordering and reparing it and when I put it back together it didn't work. I installed it correctly, however there's no power getting to the motor. Both window fuses are fine, as is the switch. All other windows work correctly. Now when I say I finally got around to fixing it it's been 6-8 months.......... I've done some other troubleshooting/repairs and can't figure out if something I did would of caused the no power issue at the motor. Motor works, I tested it. I haven't taken out the ECU yet though that's next I think.... I looked at the wiring diagrams on Rave and it doesn't show any relays which I was playing around with eariler (2-3 months ago) and initially though that perhaps I swapped it out with a bad one. Is there anything I'm missing?
Old Oct 11, 2009 | 07:47 PM
If it is the rear windows not working fro lack of power then most likely there is a broken solder joint on the window lift ECU.
It is behind the glove box, remove it, look for cracks, repair, windows should work.
Old Oct 12, 2009 | 05:48 PM
parajumper's Avatar
OK call me Captain Obvious! So after 1 1/2 days of pouring over schematics, tearing apart the entire interior to include the center console looking for the C301 connector, I finally gave up and assumed that at least the connection was good from the ECU up to the motor as I was getting power to the switch and everything was connected up until the door. So I decided to put the door back together. As I assembled the components and placed them one-by-one into the door, I finally got to the door panel and lo and behold there is a window switch I haven't connected to complete the circuit............. =-D. Well on a good note it did cause me to visit these forums and I came across the Front Differential and U-Joint issue. Upon inspection one of the U-Joints was rusted and looked like it didn't have much life left so disaster averted via a $24 fix. Thanks again forums!!
Old Oct 12, 2009 | 05:56 PM
Glad your windows are working again.
The front driveshaft issue just so we are clear only affects DII's not DI's.
Maybe you'll stick around.
Lori Ranocchia Gilhooley
Aug 5, 2014 11:12 AM
jekylczar
Dec 7, 2013 07:45 PM
tw_salisbury
Mar 10, 2013 06:26 PM
pinkytoe69
Nov 20, 2012 07:42 PM
bigfun
Mar 14, 2008 09:27 PM
