Disco 2 power window issue
Old Aug 5, 2014 | 09:38 AM
Lori Ranocchia Gilhooley's Avatar
3rd Gear
Default Disco 2 power window issue
During the winter months I started having an issue with the passenger side front power window, it would not operate until the cabin warmed up, then it was fine. The truck has been out of commission since May, while I tried to figure out severe overheating. Shes back up and running, now the window wont operate at all, I hear what I believe to be a relay click under the glovebox when the switch is hit. Give me some input guys, after this overheating thing, I am not in the mood to chase the ghost. All fuses and relays are good, checked and double checked. When the window worked there was no drag, or chattering, it went up and down fine. ECU? Power plug into the door? Any ideas?
Old Aug 5, 2014 | 11:12 AM
evoblade's Avatar
Do you have a way to test the window switches?
jekylczar
Dec 7, 2013 07:45 PM
tw_salisbury
Mar 10, 2013 06:26 PM
pinkytoe69
Nov 20, 2012 07:42 PM
parajumper
Oct 12, 2009 05:56 PM
bigfun
Mar 14, 2008 09:27 PM
