98 Disco I Suspension
When up to speed and I let off the accelerator, my Disco I pulls/lurches to the right. When I press the accelerator again, it pull/lurches back to the left. Very disconcerting and IMO a safety issue. Looking at the rear sway-bar, it appears it is moving back and forth in the bushings. I intend to replace the sway-bar to frame bushings this weekend and the radius arm bushings next week in an attempt to remedy the situation. Any other recommendations?
Thanks!
Steve
Thanks!
Steve
Have the arm that comes off the power steering pump checked.
The Disco I will (walk) when you accelerate and pull back when you let
off but not to the extent that it sounds like yours is.
My Disco would wander going down the road and I though it was the
alignment it was that arm. I had a alignment done at a dealer
and they found the problem. With the alignment and arm it was
about $ 175.
Mike
about $ 175.
Mike
fastrx7man
Jan 28, 2012 12:49 PM
