98 Disco problems
Old Apr 13, 2009 | 09:47 PM
GreenMachine's Avatar
4th Gear
Default 98 Disco problems
OK today hooked up the Rover to a scanner and the results are as follows,
P0308 #8 cylinder misfire, and P1187 O2 sensor. i have not replaced the plugs or wires yet. Like i said the truck runs normal despite it running rich. so does anyone have any ideas?
Old Apr 14, 2009 | 06:22 AM
LANDZUII's Avatar
Bad plug / wire ,, bad 02 sensor.
Classic Disco's need the 02's changed at 82,000 miles has that been done?
Even if the 02's have been changed you can have a bad one or mess it up on install.
If you keep running rich get ready to replace your cat's.
Old Apr 14, 2009 | 08:45 AM
AK Rover's Avatar
Replace your plugs and wires first. A lot of O2 codes are caused by bad plugs and wires. How many miles on your truck? Regardless I am thinking that your O2 sensors are near dead since the truck is a 98. Running rich will destroy your cats like landzu said.
Frank4
Mar 21, 2014 05:21 AM
JohnJaquaIII
Aug 15, 2005 12:47 AM
markwbball
Jul 12, 2005 10:05 PM
DiscoGirl
Feb 22, 2005 01:02 AM
RICHARD1958
Jan 9, 2005 09:07 AM
