98 disco serpbelt issues
Old Sep 7, 2008 | 01:22 PM
kecracing's Avatar
3rd Gear
Default 98 disco serpbelt issues
My 98 disco has some serpbelt issues. It was worn and squeaking and I replaced it. After I change it I noticed it s walking back and forth on the tensioner pulley. The tach works intermittently and if I turn A/C it it runs true and noise is gone and tach is ok? Any help would be appreciated. I am guessing bad tensioner? Thanks, in advance
Old Sep 7, 2008 | 01:46 PM
Default RE: 98 disco serpbelt issues
If the belt is "walking" on the pullies thenI would say bad tensioner.But I would double check the routing first though.
http://www.roverparts.com/TechTips/s...g_defender.cfm
Old Sep 7, 2008 | 01:54 PM
Willie 00D2's Avatar
Could be the bearings in the a/c clutch. See if you feel any play in it, It should be tight. Also look at the tensioners like spike said.
Willie
Old Sep 7, 2008 | 04:06 PM
Tensioner and I would replace both the idler pulleys at the same time. Pretty common to see them all fail at nearly the same time.
Old Sep 7, 2008 | 08:09 PM
kecracing's Avatar
3rd Gear
My disco only has 74k and I routed belt the same as I removed it. I think tensioner and idlers are ok. There is no play and no separation on tensioner. I see from link that belt is routed incorectly. I will switch to proper routing and see what hapens. Thanks for the info.
Old Sep 10, 2008 | 12:51 AM
kecracing's Avatar
3rd Gear
All is good!! Proper belt routing worked. Thanks for the help!!!
Old Sep 10, 2008 | 08:04 AM
Glad to here tht it worked.
Crashdevil13
May 24, 2007 08:52 AM
Orfordrover
Dec 2, 2006 08:44 PM
dbwarren
Nov 14, 2006 07:14 PM
CPDieker
Sep 25, 2006 08:37 PM
richo888
May 12, 2005 11:50 PM
