99-00 4.6l vin
Old Apr 18, 2013 | 02:16 PM
Dan7's Avatar
Default 99-00 4.6l vin
Just got my engine from Great Plains and was trying to confirm some info by looking up the VIN. Couldn't find it and when asked, they told me there is no VIN...it's just on the chassis. is this correct? Any other way to verify it's a block from a 99-00 Range Rover (what I specified)?
Only marking I found was WYF10HRC2411 which I've found no info on.
Old Apr 18, 2013 | 02:21 PM
jafir's Avatar
Engine serial number - V8 engine
Stamped on a cast pad on the cylinder block, between numbers 3 and 5 cylinders.
NOTE: The engine compression ratio is stamped above the serial number.
If you can locate the serial number, you can probably compare it to known 4.6L engines from P38A Range Rovers.
Old Apr 18, 2013 | 02:22 PM
ZGPhoto's Avatar
Vin would be on the front dash(in front of the steering wheel, seen from outside the vehicle) and also in the pass. side rear wheel well on the chassis. Possible one in a door jam too, can not recall.
Old Apr 18, 2013 | 02:34 PM
Dan7's Avatar
OK, so nothing on the block. Nothing to work with really then. I'll call the dealer and see if they can make heads/tails of that # I found on there. Thanks! Will hopefully be posting a thoroughly photographed install soon.
Old Apr 18, 2013 | 02:41 PM
ZGPhoto's Avatar
I'm not positive if there's anything on the block, but there certainly could be.
NiteTrain
Oct 17, 2008 11:20 PM
snowdude
Sep 11, 2008 01:34 PM
negativecapability
May 7, 2008 03:21 PM
DrLivingston
Nov 23, 2007 12:46 AM
ScottJ
Oct 2, 2007 02:19 PM
