'99-'02 Discovery II Lift?
Old Mar 26, 2008 | 05:43 PM
lonewolf's Avatar
Default RE: '99-'02 Discovery II Lift?
Thank you very much for the link. It should help out a lot. I will give him a call tomorrow.
Old Mar 26, 2008 | 06:07 PM
lonewolf's Avatar
Q: Do you plan on taking it off road?
A: I will be using it to go hunting in Northern Minnesota, Alaska and Canada for Bear. I will undoubtedly encounter some terrain. So yes, I will be going off road, but not climbing mountains or driving over cars like in the video you posted. More like the stuff you would see at a Land Rover test track. Still if the opportunity came along, I would happily go mudding through a swamp. Does anyone know about fender trimming, backspacing, etc...?
Q: Will the brakes and axles be able to handle 40" tires?
A: I do not know for sure, but I am planning to have longer axles installed to give better tire clearance in turns. I will make sure that they are strong enough. As far as the breaks are concerned, I never imagined that the stock breaks would be compatible with the new and significantly larger tires and wheels, but I did completely forget about factoring in that cost. I could use some suggestions for both the breaks and the axles. The wheels are 20 inches in diameter and 12 inches wide and I am now looking at 36 inch Mickey Thompson Baja Radial SLT tires (size: 36X15.50R20LT). If I can go bigger, I will (up to 40 inches in diameter).
Even though you did not give me answers, these are important questions that I had not considered before now and I appreciate your input. Thank you very much.
Old Mar 26, 2008 | 06:11 PM
lonewolf's Avatar
I see in your signature that you have a custom rear bumper and I would like to get one as well. I like ARB, but they appear to not offer rear bumpers for rovers. Where did you go?
Concerning my axles, diffs bearing, t/case and the whole power train in general, what would you recommend?
Old Mar 26, 2008 | 06:25 PM
WolfPack's Avatar
Click on the link on the RoverTym website about the SilverBeastie. Looks to be about what you're wanting to run..maybe a little small on the tires though.
Old Mar 26, 2008 | 06:37 PM
lonewolf's Avatar
Looks good. Thanks for the idea, but I could use some more. Does anyone else have any input regarding my situation?
Old Mar 26, 2008 | 06:52 PM
lonewolf's Avatar
Bad news. The red discovery was just sold to another buyer, so I am still in the market. Thanks any way guys. When I get another one lined up, I will be back.
Old Mar 26, 2008 | 07:30 PM
Have you ever owned a 4 wheeler? 40"s on a Disco is crazy, the truck can't handle it and it is a disadvantage off road.
Longer axles aren't an answer, the diff tubes can't handle the stress from those tires.
If you want to build a Disco, listen to people who have them and build acordingly.
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
