99-04 Disco II Steering Damper Stabilizer Length
Old Feb 23, 2010 | 05:01 PM
NOPAINT's Avatar
5th Gear
Default 99-04 Disco II Steering Damper Stabilizer Length
Hello all. I am from a benz forum and would like to tap into some land rover knowledge to see if I can remedy a problem we are plagued with. The steering damper or steering stabilizer on our vehicles are rather weak and the only replacement available comes in the form of a stock replacement that is mis-manufactured. Eventually the shock starts leaking or underperforming and needs replacement. The issue is not that we are trying to mask anything but instead that the shocks are just low quality.
Nonetheless, I think the Discovery II steering shock from 99-04 may fit. I was wondering if anyone could give me the following:
Extended Length Eyelet to Eyelet
Compressed Lenth Eyelet to Eyelet
If there are any other dimensions you feel like taking that would be wonderful but not necessary at the moment. Thank you for your help and cheers.
LARRY
Old Feb 24, 2010 | 08:57 AM
NOPAINT's Avatar
5th Gear
Pretty please
I would be really grateful if someone could climb under their 99-04 and measure the steering stabilizer...Thanks guys.
Old Feb 24, 2010 | 09:03 AM
okdiscoguy's Avatar
All I can tell you is that my D1 is 18" right in the middle...have to take it off to find full extension and compression.
Old Feb 24, 2010 | 10:04 AM
NOPAINT's Avatar
5th Gear
Thank you. I wish a D1 would work but it has different mounts. I need length from a Discovery II. If anyone could steer all the way left and measure then all the way right and measure I would be incredibly grateful!
Old Feb 24, 2010 | 10:08 AM
okdiscoguy's Avatar
what length do you need?
Old Feb 24, 2010 | 11:56 AM
NOPAINT's Avatar
5th Gear
15.1875 X 24.875 (roughly). I think the DiscoII operates somewhere in that range and has an eye on each side.
Old Feb 25, 2010 | 07:38 AM
NyTelTech's Avatar
Sorry, last post had the D1 dimensions. First is compressed, second is extended
I hope this will help you. I found these dimensions on the OME site:
OMESD11
Steering Damper
15.5
25.5
You can view thier specs at:
http://www.expeditionexchange.com/ome/indexshocks.php
Old Feb 25, 2010 | 09:26 AM
Here is a link that will give you the information you want.
http://www.expeditionexchange.com/om...steeringdamper
Old Feb 25, 2010 | 03:55 PM
NOPAINT's Avatar
5th Gear
You guys are wonderful! Thank you so much from the whole community of offroad enthusiasts. Looks like the DII steering stabilizer is very close if not exactly what I need. I will purchase a cheapo and if it works I will be putting on an old man emu model!
thehun
Mar 10, 2011 08:11 AM
mrcrptguy
Apr 3, 2009 12:52 PM
cptshanman
Sep 1, 2008 12:28 PM
andrewmcoffin
Mar 11, 2008 09:22 PM
okdiscoguy
May 18, 2007 09:56 PM
