99 DII won't rev past 3000rpm in park?
Old 06-19-2010, 07:19 PM
Robwsup's Avatar
Default SOLVED - 99 DII won't rev past 3000rpm in park?
***UPDATE - Solved, see last post***
MY DII w/ 120000 miles won't rev past 3000rpm in park. It idles smooth, has new Mag 8mm wires and new plugs. It was throwing misfire codes, but hasn't got any new codes since the plug/wire change.
It has little to no acceleration, and hesitates to rev to 3000 rpm.
I've got strong exhaust coming out of the tail pipe, but I know that "strong" is relative.
I don't think it is fuel pressure/supply related, as it takes little fuel to rev an engine out of gear.
Maybe blocked cats? How can you tell?
Old 06-19-2010, 08:12 PM
I am betting on low fuel pressure.
The only way to know for sure is to check the fuel pressure with a fuel pressure tester.
Old 06-19-2010, 10:37 PM
Robwsup's Avatar
Where can I hook up a pressure tester? It's dark out, so I can't poke around now.
I wonder if Harbor Freight stocks a fuel pressure tester?
Are you thinking fuel filter or pump?
How can I check the cats? I know I can bonk them with a hammer, but is there any other way to check them?
Old 06-19-2010, 10:41 PM
Robwsup's Avatar
Would this kit work? It says "except Bosch", but I'm not sure what the DII uses:
http://www.harborfreight.com/fuel-in...ter-92699.html
Old 06-19-2010, 10:56 PM
d2luvr's Avatar
The DII is a Bosch fuel injected engine.
Old 06-19-2010, 11:52 PM
lordmorpheus's Avatar
I don't know for sure, but I would guess they are talking about the older Bosch systems found on German cars from the 70s through the 90s: L-Jetronic, K-Jetronic, etc. I would imagine a DII Schroeder valve would be fairly standardised.
Old 06-20-2010, 12:09 AM
Robwsup's Avatar
I was hoping they meant the Jetronic systems, like on older Porsche's.
I'll probably go pick it up tomorrow, it the local store stocks it. I'll plug it up in the parking lot, if it doesn't work I'll return it. Either way, I'll let you guys know.
Old 06-20-2010, 07:20 AM
Why not start with the basics, what are you current fault codes?
No, D2's are hard as hell to read fuel pressure from.
Old 06-20-2010, 10:25 AM
Robwsup's Avatar
I have no fault codes.
Old 06-20-2010, 01:48 PM
Robwsup's Avatar
I just had some codes set after some rough driving:
P0305 Cyl 5 Miss
P0733 and P0734 Incorrect 3rd and 4th gear ratio
I'm researching and finding that the latter may be MAF related, but usually set with P017x codes.
Quick Reply: 99 DII won't rev past 3000rpm in park?
