99 Disco 1 engine rebuild torque specs?
Old Aug 2, 2006 | 11:22 PM
sanchez's Avatar
5th Gear
Default 99 Disco 1 engine rebuild torque specs?
Does anyone have the torque specs for the head gasket bolts and gap set for the piston rings?
Thanks!
Old Aug 2, 2006 | 11:29 PM
Bait's Avatar
Default RE: 99 Disco 1 engine rebuild torque specs?
Head bolts are stretch bolts and must be replaced every time. 16 foot lbs, ninety degrees, and another ninety.
Old Aug 2, 2006 | 11:32 PM
sanchez's Avatar
5th Gear
Thank you! So, if I give this to my mechanic it will makes sense to him, right? Because you lost me at hello! Also, does my question about the piston rings make sense?
Old Aug 3, 2006 | 01:02 PM
Again, I ask WHY??
Is this man working out on your drive way.
Mike
Old Aug 3, 2006 | 10:18 PM
sanchez's Avatar
5th Gear
Nope, they normally rebuild race car engines so they are very familiar with the mechanics of rebuilding an engine just need the torque specs. That's all...Thanks for your input.
Old Aug 3, 2006 | 11:28 PM
After working with dealers, in the shop as a service writer and manager, I have to tell you, the one thing an experienced shop does not do is ask their customer for the specs.
The only reason I am bring this up is to make sure others don't fall into a trap of using just any old shop, even engine shops that rebuild engines, cause they never use the right parts, know the proper way to perform the build and know the tricks to a better Rover rebuild.
Mike
RYANHASADD
Dec 9, 2007 03:50 PM
Mark G
Nov 11, 2007 09:50 AM
El Jefe
Apr 12, 2007 08:30 PM
sneeedle
Feb 25, 2007 11:00 PM
mattcrunk
Jun 16, 2006 08:41 PM
