Quote:
I'm from Houston but the trip was to Austin and Fredericksburg which is hill country.Originally Posted by Savannah Buzz
Where did you find "down hill" in Houston?
Quote:
10-4 . Thanks for all the feedback guys I'll look into it and post a reply when I have more findings. I've ordered the 180 tstat and will let y'all know.Originally Posted by Dan7
I understood that 221 was just a spike...perhaps I should have said reaching 221F is not normal? that said, you need to find out what aspect of the cooling system isn't working properly, and you haven't ruled out air in the system until you do a pressure test. After that, install a 180F thermostat b/c even if the t-stat isn't the issue, this needs to be done anyway. There's other posts on how to check and see if your radiator is clogged by Savanahbuzz...something about taking temp readings at the top and bottom of the radiator, ensuring >10F difference. Checking the fan clutch is fairly easy if you have a basis for comparison. All these things are good preventative maintenance anyway, so you're not out the time/$ if it doesn't fix the issue.
Richard.rover
I'm in Austin so if your ever stranded or need some help with those temps let me know. I replaced my Radiator and use the 180 Stat. My temps this past week never rose above 194. It will reach 200 in the heat of the summer in bumper to bumper traffic.
Thanks for the offer. This texas heat can really kill a car! I'm hoping to change the tstat and see where I stand. Savannah buzz had said he uses a fan from a Chevy blazer. Anybody use it on a disco2?Originally Posted by ralphobell
Richard.roverI'm in Austin so if your ever stranded or need some help with those temps let me know. I replaced my Radiator and use the 180 Stat. My temps this past week never rose above 194. It will reach 200 in the heat of the summer in bumper to bumper traffic.
Quote:
Where are you at now? Temp wiseOriginally Posted by dusty1
with my old original stat i would see summer spikes around 215
Quote:
Today in the cool weather low in the high 30's highs in the mid 40's I ran from 188 to 194.Originally Posted by Richard.rover
dusty1
close
- Join DateJul 2013
- Locationdallas texas
Liked:211 Times in 194 Posts
Quote:
182-188 tops.....but I dumped the bypass all together. 186- 195ish with spikes up to 205 with the 180 bypass before I convertedOriginally Posted by Richard.rover
Quote:
What bypass are you talking about?Originally Posted by dusty1
And when off roading in the desert with ambient temps of 115 degrees my engine doesn't go above 200, And that's with the stock 190° thermostat
dusty1
close
- Join DateJul 2013
the 3rd hole in the stat. y is the bypass. and 200 is good. have you checked the spikes when the engine is shutdown for about 6-8 minutes? that is my concern. my high temp spikes are all from heat soak....after the engine has been shut off.
