99 disco 2 temperatures-road trip
I understood that 221 was just a spike...perhaps I should have said reaching 221F is not normal? that said, you need to find out what aspect of the cooling system isn't working properly, and you haven't ruled out air in the system until you do a pressure test. After that, install a 180F thermostat b/c even if the t-stat isn't the issue, this needs to be done anyway. There's other posts on how to check and see if your radiator is clogged by Savanahbuzz...something about taking temp readings at the top and bottom of the radiator, ensuring >10F difference. Checking the fan clutch is fairly easy if you have a basis for comparison. All these things are good preventative maintenance anyway, so you're not out the time/$ if it doesn't fix the issue.
Richard.rover
I'm in Austin so if your ever stranded or need some help with those temps let me know. I replaced my Radiator and use the 180 Stat. My temps this past week never rose above 194. It will reach 200 in the heat of the summer in bumper to bumper traffic.
Thanks for the offer. This texas heat can really kill a car! I'm hoping to change the tstat and see where I stand. Savannah buzz had said he uses a fan from a Chevy blazer. Anybody use it on a disco2?
182-188 tops.....but I dumped the bypass all together. 186- 195ish with spikes up to 205 with the 180 bypass before I converted
And when off roading in the desert with ambient temps of 115 degrees my engine doesn't go above 200, And that's with the stock 190° thermostat
the 3rd hole in the stat. y is the bypass. and 200 is good. have you checked the spikes when the engine is shutdown for about 6-8 minutes? that is my concern. my high temp spikes are all from heat soak....after the engine has been shut off.
